Date/Time: Mon, 25 Nov 2024 06:36:57 +0000
2 number bars in the same window
View Count: 1101
[2014-01-20 18:59:53] |
MMX - Posts: 119 |
I want a number bar in region 1 and I want a number bar in region 4, same symbol, same periodicity, identical, I just want to configure them differently. I've done everything I can think of in trying to get the overlay study or the study/price overlay study to do this but the number bars still won't show up in region 4. I've added a second number bar to the window, same thing, a new region 4 is created but it's blank. Is it even possible to have 2 number bars, each in their own region, within the same window?
[2014-01-20 19:06:26] |
No. This is not supported.
