Date/Time: Thu, 06 Feb 2025 20:33:08 +0000
Denali with Oneup Trader
View Count: 999
[2020-05-11 16:55:18] |
User502795 - Posts: 5 |
Hi. Will I be able to trade with Oneup Trader with Denali data feed? Or do I have to have Rithmic? Thanks.
[2020-05-12 00:26:47] |
You would need to use the Rithmic data feed unless you have a funded trading account and then you can use the Denali Exchange Data Feed.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-12 00:27:00
