Date/Time: Thu, 06 Feb 2025 21:56:02 +0000
A big issue!
View Count: 515
[2020-05-11 16:30:52] |
User676682 - Posts: 4 |
hello... after the new updates with milisecond and with delayed data. i found many losses in my system here on sierrachart but the stupid thing is i have backtested the period of NQ 2020-03-23 - 2020-04-26 and here is a good result! moore than 10k defference between before update and after update... that isnt normal!? now, after new updates from sierra-side i have here fristly a big loss and secondly a big drawdown! can you tell me what is here wrong. i have do the absolutyl same like all other time. !!! ??? i used the Volume-custom-study and on a 10min chart. please help me! i used a normal trail version now but on last backtest i have also used a normal trail version used! thx. Date Time Of Last Edit: 2020-05-11 16:32:43
[2020-05-12 19:45:51] |
We are not sure what you are referring to here?: . after the new updates with milisecond and with delayed data.
