Date/Time: Mon, 25 Nov 2024 07:00:47 +0000
TPO with Vol at price chart
View Count: 1271
[2014-01-20 16:04:39] |
pse52 - Posts: 18 |
Can you please tell me what the red and green lines are in this chart. I cant find any setting that controls them
MP with vol at price Chart .docx - Attached On 2014-01-20 16:03:26 UTC - Size: 271.74 KB - 509 views |
[2014-01-20 18:18:28] |
These are known as the Initial Balance extension lines. They are documented here: http://www.sierrachart.com/index.php?l=doc/doc_TPOVolProfileCharts.html#ReadingTPOCharts They can be hidden by setting the IBR Extension Horizontal Lines inputs to No. The proper way to post an image is by following these instructions: https://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-20 18:19:36
