Date/Time: Thu, 06 Feb 2025 22:58:17 +0000
Color of ZERO on Study Subgraph Above/Below Bar as Text study
View Count: 949
[2020-05-11 01:04:08] |
Meklon - Posts: 223 |
Hello Support, When option Draw Zeroes is enabled on "Study Subgraph Above/Below Bar as Text" what option controls the color of the ZERO?It appears that only one Subgraph color code method is provided for this study which controls positive or negative value based on +/- but there is not color control for neutral (Zero) text. Does this default to some setting on the Chart Graphic? |
[2020-05-12 21:28:42] |
We added the information for how 0 is handled in the documentation here: Chart Studies: Based on Positive/Negative This is not something that can be changed unless you modify the study yourself and create your own custom implementation: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-12 21:29:28
[2020-05-13 23:49:56] |
Thank you Support
