Date/Time: Mon, 25 Nov 2024 06:32:48 +0000
Intraday session times
View Count: 1540
[2014-01-20 15:31:39] |
pse52 - Posts: 18 |
I'm having difficulty getting my charts set to pit and globex session start times and end times. They are also set in the chart settings, and I don't see an option to turn it off. I set the times in global symbol settings and unchecked "apply intraday start times to intraday charts." But if I change the the symbol to GCg4 the session times remain the same, even though I set them differently in global symbol settings and click "apply global symbol setting" in the chart settings.
[2014-01-20 16:22:15] |
You do need to enable Apply Intraday Session Times to Intraday Chart in Global Settings >> Symbol Settings for the Session Times to be applied when you change the symbol of the chart. Here is the complete documentation: http://www.sierrachart.com/index.php?l=doc/doc_GlobalSymbolSettings.php#SettingIntradaySessionTimes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-01-20 16:22:47
