Date/Time: Thu, 06 Feb 2025 20:02:59 +0000
Rythmic connection
View Count: 1009
[2020-05-10 01:47:24] |
User302675 - Posts: 1 |
I am a first time user just stting up Sierra charts. Going to do a trading tryout with SMB. I get an error message (attached) saying the Rythmic bridge is missing and to reinstall the program I have done this numerous time trying all different versions and no "C:\Sierrachart\Rim\DTCBrige.exe" ever gets installed. Is it still possible to use rithmic for this tryout or should I ask SMB for other options. I have used Ninja trader for years and would like to give Sierra Chart a try. thanks for any help or advice you can give me. Jim |
[2020-05-10 07:30:01] |
We have just contacted SMB about this. We have discussed with them using the Simulated Futures Trading service here: Simulated Futures Trading Service That is available to them now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
