Date/Time: Wed, 12 Feb 2025 06:45:08 +0000
[User Discussion] - Swing High and Low
View Count: 1251
[2020-05-09 17:01:06]
User710679 - Posts: 43
is there any way to draw the swing high and low the same way that it is shown in the attachment? I mean with those lines with a pre-defined size instead of extending the line until an intersection with the price.
thanks!
David
imageFractals.png / V - Attached On 2020-05-09 17:00:09 UTC - Size: 280.16 KB - 380 views
[2020-05-09 19:15:04]
Ackin - Posts: 1865
Hi, you can download it...
Free study: Swing high low pivot line
contact link:
imageswing HL pivot.png / V - Attached On 2020-05-09 19:14:13 UTC - Size: 52.8 KB - 343 views
[2020-05-09 19:20:05]
Looks very good. Con you post the configuration parameters? Or it looks like that by default?
Thanks a lot!
[2020-05-09 20:26:00]
Ackin - Posts: 1865
it is modified study from SCH. There was added a lot of rows of code. Parameters is easy - "superlevels" and this is result.
Study is free as DLL on our CZSK forum. Download it if you want....
[2020-05-13 13:46:35]
User267701 - Posts: 66
I did register in the CZSK forum but didnt get an email yet.
[2020-05-13 14:06:45]
Ackin - Posts: 1865
Send me email please
zyp.sierra@gmail.com
[2021-05-24 15:29:14]
User61576 - Posts: 445
thanks. can you also share the code, please?
[2021-05-24 17:50:30]
also, i notice there is no difference between delta and volume. is there a bug or I don't understand how to use it?
