Date/Time: Thu, 06 Feb 2025 20:11:06 +0000
Decimal rounding in stocks
View Count: 684
[2020-05-09 04:26:53]
User841513 - Posts: 15
I am using SC for charting penny stocks that usually are priced on tenths or more of a penny.
It seems all the cahrts round to the penny. I go to chart settings and change the price display format and even the tick size and I get a correct graph but when I change symbol, the chart returns to the rounded to penny version.
How can I handle this? I can't add lines or other tools because they move according to the tick size.
Thanks for your help.
[2020-05-10 10:20:15]
What you need to do is enable this option in the Chart Settings:
Chart Settings: Do Not Change Symbol Settings for Chart on Symbol Change (Chart >> Chart Settings >> Symbol >> Symbol Settings menu)
Date Time Of Last Edit: 2020-05-10 10:20:23
