Date/Time: Thu, 06 Feb 2025 20:16:55 +0000
Denali Data Book Levels
View Count: 564
[2020-05-08 23:26:44] |
Sting111 - Posts: 2 |
I just subscribed to Denali through AMP with the Full CME book option. The DOM only has 20 levels. I look at people system with Sierra and Denali and they have 30+ levels. Please advise.
[2020-05-09 22:25:19] |
In some cases there are over 1000 levels. Check the following for settings to make sure that they are not limiting your levels: File Menu: Not Receiving the Full Number of Market Depth Levels If this does not solve your problem, then let us know the symbol you are looking at. ---------------- Unrelated to this, we see that your Agreements for the Denali Exchange Data Feed have not been processed since you did not have a correct address entered on them. Please update your address here: https://www.sierrachart.com/UserControlPanel.php?page=ManageAccountInfo And then resign the agreements here: https://www.sierrachart.com/UserControlPanel.php?page=ExchangeAgreements This is important otherwise we have to cancel the Denali Data Feed on your account. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-09 22:25:41
