Date/Time: Fri, 25 Sep 2026 13:13:23 +0000
weekly charts
View Count: 2931
[2020-05-08 20:48:57]
Barbara Tobias - Posts: 35
I have the daily intraday charts set up .. but I want to set up a weekly chart. I need a bigger price range and I was told not to use the intraday, but to use the weekly. But I need direction in how to set this up. Can someone help.
[2020-05-10 22:34:12]
You just simply open a Historical Daily chart:
Getting Started, Opening Charts and Basic Trading: Open A Chart
And set the timeframe to weekly using any of the methods documented here:
Changing Chart Bars Period
Date Time Of Last Edit: 2020-05-10 22:35:02
[2020-05-11 13:51:33]
my charts do not look like that .. - how do I change it to weekly . It won't let me copy to this. Btu I went to historical Daily chart and it doesn't look like mine
[2020-05-11 14:06:13]
I have tried to follow instructions - but it does not work for some reason and it won't let me copy chart. Followed the instructions on screenshot/image above. BCRX
Private File
[2020-05-11 20:19:00]
The chart in the image you provided is a 3 minute chart. Just change the time period of the chart to weekly using any of the methods described in this documentation:
A simple way is to go to that chart and select Chart >> Bar Periods >> Weekly on the menu.
