Date/Time: Mon, 25 Nov 2024 06:58:05 +0000
Sierra on multiple computers
View Count: 2004
[2014-01-20 13:55:01] |
darkpool - Posts: 39 |
Hi, I am coming to the end of my Sierra trial and plan on purchasing package 5 next week. The trial has proved Sierra to be an excellent platform! One question though, I have a primary trading computer and a backup laptop. I've been using the trial on the desktop and according to this link: http://www.sierrachart.com/index.php?l=doc/PurchaseInformation.php#Licensing it should be possible to use Sierra on multiple computers (up to 2 concurrently). My main requirement is simply to be able to use Sierra on my laptop if there is a power failure. No need to be using them concurrently,...but I do need the laptop as a backup. I have tried using Sierra on my laptop just to make sure everything works correctly, but it wont let me log in. Please advise if this is simply a restriction due to the fact that im still on the trial, and that when I purchase package 5 next week I will be able to use both computers. I presume it has nothing to do with broker / data feed restrictions? Many thanks. |
[2014-01-20 15:51:13] |
Sierra Chart - Max - Posts: 5730 |
The limitation is because you are a on a trial. We have removed the limit, and you should be able to login on multiple computers.
Sierra Chart Support |
[2014-01-20 16:07:55] |
Thanks very much.
