Date/Time: Thu, 06 Feb 2025 20:22:49 +0000
automatically flatten is still flattening itself when swiched to disabled status
View Count: 710
[2020-05-08 18:32:18] |
User156295 - Posts: 104 |
Dears 1- I have set in Trade Window to Flatten&Cancell at Set Time and saved as configuration. Than I change it not to flatten and saved again under the same name with other settings. 2 - I also put in Global Settings > Global P&L to flatten positions at given time. And SC is still flattening positions from point 1 as above. Can not find the reason, checked all settings in Trade Window, set any configuration to "disabled" status and still there is flattening. Pls advise. Thank you. |
[2020-05-08 21:05:05] |
What you need to do is determine the origin of that particular Flatten order. Instructions: Trade Activity Log Analysis: Determining the Origin of a New/Modified Order Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
