Date/Time: Thu, 06 Feb 2025 18:51:31 +0000
chartbook uploaded delayed by 10 mins - setting?
View Count: 505
[2020-05-08 00:51:44] |
User118473 - Posts: 16 |
Hi, i uploaded chartbook /ES onto Sierra and its set to 10 min delay on data feed - is there a way i could make this Live and back to 10min delay or even 30 min delay? Thank you, Jonathan |
[2020-05-08 06:28:00] |
You are not getting real-time data because AMP did not complete the setup of the Denali Exchange Data Feed here for you: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliExchangeDataFeed Ask them to do that for you. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
