Date/Time: Thu, 06 Feb 2025 18:37:58 +0000
Global Profit / LOSS Management
View Count: 892
[2020-05-07 18:42:11] |
User886756 - Posts: 15 |
Are you kidding? I´ve set up the Global Profit / LOSS Management correctly, it always worked. Apparently not since the last update. I lost more than 1000 USD today because the software doesn't work. I can send you a screenshot of it. Unfortunately, I won't bring my money back. THANK YOU SIERRA CHART!
[2020-05-08 07:07:37] |
You really have to be very careful with this feature and monitor it at least a few times a day to make sure it is working as expected. This is all explained here: Global Profit/Loss Management For status information, refer to: Global Profit/Loss Management: Monitoring Status This functionality is going to be most stable, when used with this service: Sierra Chart / Trading Technologies Futures Order Routing Service In combination with this option: Chart Settings: Filter Initial Fills Which Are Part of Existing Position (Chart >> Chart Settings >> Trading menu) There are no problems with Global Profit/Loss Management in the latest version. To demonstrate that, do testing using a chart replay. For testing enable Global Settings >>Global Profit/Loss Management >> Support Replaying Charts. We do not need to see any screenshots. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-08 07:08:45
