Date/Time: Thu, 06 Feb 2025 19:23:30 +0000
Intermittent Data Disconnections
View Count: 602
[2020-05-07 16:37:36] |
User187934 - Posts: 40 |
My data feed connection is randomly disconnecting and reconnecting and I am not sure what is causing the issue. I receive the following in the message log. DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2020-05-07 09:33:21.711 * DTC Client socket (3) | Socket receive error. Windows error code 10054: An existing connection was forcibly closed by the remote host. | 2020-05-07 09:33:21.711 Could you please advise as to what the issue may be and how it can be resolved? |
[2020-05-08 07:20:30] |
This is going to because by a network connectivity issue from your location. Refer to help topic 1.2: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem We need to see the entire Message Log at the time to see what connection you are having a problem with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-08 07:20:45
[2020-05-08 11:21:42] |
Is there a way to retrieve that log or must I wait for the issue to occur again and then contact you with the new log?
[2020-05-08 11:23:17] |
Yes wait for it to occur again and post it here.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-08 11:23:25
[2020-05-08 11:30:13] |
Done for the week so will pick it up again next week. Thanks for the help.
