Date/Time: Thu, 06 Feb 2025 17:46:03 +0000
Scaling The Numbers Bars
View Count: 860
[2020-05-07 16:20:05] |
User769783 - Posts: 188 |
How can I scale the Numbers Bars to fully show on my screen without using the volume multiplier. Using the multiplier changes the readings of the bid X ask footprint. When I do not use the multiplier, the numbers bars are extremely large, and I have to drag the chart up and down to view all the bid x ask levels. Any help I'm truly grateful, thanks.
[2020-05-07 19:07:20] |
You really cannot necessarily do this because likely you will have a case where the numbers are not readable. These are the instructions to use an Automatic Scale and not have any of the bars cut off: Chart Scale and Scale Adjusting: Chart Bars or Studies Not Completely within View, Not Displayed, or Cut Off. Reset Scales. Also refer to: Numbers Bars: Scaling a Numbers Bars Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-07 19:08:10
