Date/Time: Mon, 25 Nov 2024 06:33:48 +0000
chart alert setup
View Count: 1086
[2014-01-20 08:32:41] |
512kaipei - Posts: 1 |
is it possible to setup a chart alert which is ONLY triggered for certain bar periods when the condition is true?
[2014-01-20 17:47:18] |
This can be done by making reference to the cells on a Spreadsheet which indicate the time period of the chart bars. Refer to these cells: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php#CellJ36 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-01-20 18:11:59] |
We need to clarify what we said in the previous post. You need to use the Spreadsheet System/Alert study and then the formula can make reference to the spreadsheet cells that indicate the time period of the chart bars. Here is the documentation for this study: http://www.sierrachart.com/index.php?l=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
