Date/Time: Thu, 06 Feb 2025 18:53:40 +0000
study: profit loss text
View Count: 616
[2020-05-07 16:09:30] |
AKR - Posts: 523 |
Is there a way to use that study on a chart showing ES but trading MES? because it shows some wrong figures like that. |
[2020-05-08 07:42:00] |
Make sure the setting is correct: Chart Settings: Currency Value Per Tick (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-08 13:54:06] |
AKR - Posts: 523 |
OK, but how can I set it to start zero with new day /session? it sohows open PL zero, but 120 trades or so.
