Date/Time: Thu, 06 Feb 2025 19:47:45 +0000
decrease bar spacing locked
View Count: 634
[2020-05-07 14:42:36] |
User223281 - Posts: 58 |
Hello, When I try to decrease bar spacing, it lets me go out for a bit, but always snaps back to the original view. its like its locked or something |
[2020-05-07 19:26:09] |
Most likely the chart is using Chart Linking to another chart and is using the option for Bar Spacing. Refer to the information here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#LinkNumber Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-08 15:35:16] |
It is not using Chart Linking. It is only sharing drawings with another chart. In chart linking the link number selected is 'none' and there are no options checked.
[2020-05-08 19:51:02] |
This is not making sense then. So you decrease the bar spacing and then it changes back? In the lower right of the chart the bar spacing is indicated. What are you decreasing it to and then what is the changing back to? When does it change back?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-08 19:51:08
[2020-05-08 19:55:20] |
It wont let me go past 164.
[2020-05-08 19:58:06] |
Remove all studies from the chart. Maybe a custom study is changing the spacing. The other thing to do is to create a new Chartbook and open just one chart without studies and see if you have any problem there.
