Date/Time: Fri, 25 Sep 2026 17:18:19 +0000
Operacion Instrumento ES / MES
View Count: 996
| [2020-05-07 14:38:14] |
| User430258 - Posts: 1 |
Buenos dias, Al dia de hoy tengo configurado mi grafico para que me muestre el movimiento del precio para el instrumento ES y para que el trade se ejecute en con el micro (MES), sin embargo, no sucede asi ya que la operacion esta siendo tomada en el ES. ¿Que podria estar pasando? ¿como soluciono? Agrdezco la ayuda prestada a la prsente solicitud. Juan Date Time Of Last Edit: 2020-05-08 07:02:49
| [2020-05-08 07:04:27] |
Good morning, The problem is you are trading from the wrong Trade Window which does not belong to that particular chart. Refer to:As of today I have configured my chart to show me the price movement for the ES instrument and for the trade to be executed in with the micro (MONTH), however, this does not happen since the operation is being taken in the IS. What could be happening? How do i fix it? I appreciate the help given to this request. Juan Basic Trading and the Trade Window: Opening Trade Window for Chart or Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
