Date/Time: Thu, 06 Feb 2025 17:37:44 +0000
Force SC to download inactive chart data
View Count: 482
[2020-05-07 12:51:46] |
jasongleamour - Posts: 25 |
Hi, I am following around 30 pairs. Is it possible to configure SC to download data for the instruments that are on watchlist (and not open)? Sometimes I need to do quick actions and I have to wait for the data to download after swithing to an instrument. Thanks |
[2020-05-07 13:04:17] |
Yes refer to: Global Settings Menu: Intraday File Update List (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
