Date/Time: Tue, 29 Sep 2026 08:24:30 +0000
Using trade and current quote symbol breaks net p/l, profit and loss management
View Count: 1058
| [2020-05-07 03:17:50] |
| T44 - Posts: 363 |
Chart #1 is a DOM with symbol ES and trade and current quote symbol MES. Placing a 1 lot order and taking 0.5 ES points profit shows in the "Trades" tab of the trade activity log as $2.50 profit. (MES = $5 per full index point). In the "Chart Stats" tab, the "Daily Net P&L" column for chart #1 shows a P&L of $25, which is what the full size contract P&L would be ($50 per index point). Can this be fixed? I have reviewed "Solving Inaccurate Trade Statistics for Charts Field Values" in the documentation and this case is not listed. I understand that this issue will also affect Global Profit and Loss Management when trading micro contracts. Thanks. |
| [2020-05-07 05:15:21] |
Refer to: Chart Settings: Updating Currency Value per Tick for Trade Symbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2020-05-07 12:58:32] |
| T44 - Posts: 363 |
Thank you, this works for tick size, however the commission value from symbol settings for the emini ES rather than the micro ES is being applied to daily net p/l.
