Date/Time: Thu, 20 Feb 2025 19:48:11 +0000
[Locked] - Bid Ask Volume Ratio study
View Count: 1065
[2020-05-06 22:13:04] |
Josh - Posts: 1 |
Hello Would it be possible to add Candlestick Bars to the Bid Ask Volume Ratio study? This would be similar to the Candlesticks on the Bid Ask Depth Bar study. The reason for this request is due to the Line which prints only on close, omits the Open High Low of each particular bar. Thank you |
[2020-05-07 10:45:09] |
Yes we can do that. We will put this into the next release if there are no complications.
[2021-01-15 04:11:41] |
User963707 - Posts: 8 |
hi i was wondering if this was a feature now or still waiting to implement? thanks!
[2021-01-15 10:14:47] |
No this is not going to be supported. It is not possible. This is final. We are locking this thread.
