Date/Time: Thu, 06 Feb 2025 18:06:51 +0000
error code 1314
View Count: 1007
[2020-05-06 21:40:52] |
MMX - Posts: 119 |
If I correct this error , my message log will stop popping up automatically. What do I need to do to correct this error: "Error setting System Date-Time. Windows error code 1314: A required privilege is not held by the client. | 2020-05-06 16:21:54.102 *". Thanks. |
[2020-05-07 01:10:00] |
Refer to the information here about this: Global Settings Menu: Set System Date-Time from Server (Global Settings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
