Date/Time: Thu, 06 Feb 2025 17:39:49 +0000
Symbol limit to 5
View Count: 551
[2020-05-06 20:54:00] |
dluo1688 - Posts: 2 |
I have an issue to change symbol to a new symbol from my chart due to the limitation of symbol to 5.
[2020-05-07 05:20:21] |
To solve this problem we recommend that you use the Denali Exchange Data Feed: Denali Exchange Data Feed Otherwise, refer to: Chart Data and Chart Data Files: Reducing Number of Symbols Being Tracked by Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-07 05:20:32
