Date/Time: Thu, 06 Feb 2025 18:15:40 +0000
[Programming Help] - TPO 10 min off
View Count: 495
[2020-05-06 20:52:50] |
peejinator - Posts: 1 |
Hi I just figured out the setup i prefer for TPO profile, and all the windows in my trading screen. Only thing is it seems that in my TPO profile the letters start 10 min later then they should. I have them set up at 30min period length, and letters always start at primary session time to yes but they always switch to a new letter/period 10 min later than they should (910,940,etc..instead of 9,930...) Also not sure why I can't change the system time and date under global settings. I am using the demo right now on the es futures, attached my .cht, thanks!
MINES.cht - Attached On 2020-05-06 20:46:30 UTC - Size: 200.94 KB - 248 views Attachment Deleted. |
[2020-05-06 22:00:20] |
One thing to be aware of is that the data feed you are using is delayed by 10 minutes. That is the most probable explanation. Refer to: Delayed Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
