Date/Time: Mon, 25 Nov 2024 06:29:30 +0000
Volume Delta Study for lots > X & < Y
View Count: 2163
[2014-01-19 22:37:20]
pse52 - Posts: 18
Has anyone developed a volume delta indicator, similar to the cumulative delta bars, but with a setting for lot size?
[2014-01-19 22:46:31]
This is currently supported by using the existing studies and the Volume Filter in Chart >> Chart Settings:
https://www.sierrachart.com/index.php?l=doc/doc_ChartSettings.html#VolumeFilterH
[2014-01-19 23:43:05]
pse52 - Posts: 18
This should work, but if I read this correctly the volume filter is specific to the main price bars/candles so I would not be able to have two studies, one vol delta study for >5 and another for >= 1
[2014-01-19 23:54:20]
You can set up another chart with different filtering settings.
And use the Study/Price Overlay study to overlay a study from one chart onto another chart:
Http://www.sierrachart.com/index.php?l=doc/helpdetails28.html
[2014-01-20 01:51:04]
pse52 - Posts: 18
thanks
[2014-01-20 15:51:18]
pse52 - Posts: 18
This isn't working. I opened a new 3 min chart for CLH4. In advanced 2 I set >= 5 & <= 10000 and I get no prints in the cumulative delta tick bar or the cumulative delta volume bar in region 2 & 3 of this same chart. When I changed them to "0" I still get no data.
