Date/Time: Fri, 30 Oct 2026 19:33:44 +0000
Historical daily data with CQG and AMPfutures
View Count: 991
| [2020-05-06 17:06:40] |
| AC95575 - Posts: 4 |
Dear support team, I am trading futures with Sierrachart and CQG (WebAPI) at the broker AMPfutures. I am looking for daily historical data, e.g. for ES and DD. For example: What symbol shall I use to get historical daily data for ES? (EPM20 does not help, since EPM20 is a futures contract, which provides data for 3 months only.) My broker AMP said that there are 3 years of historical data for free with CQG. But he could not point me to the correct symbols. He redirected me to the CQG support. The CQG support said that CQG provides the data to Sierrachart, then Sierrachart provides them to me. So, they redirected me to you. Can you help me further please? Thank you very much in advance and best regards Markus |
| [2020-05-06 20:46:34] |
To open a chart, refer to: Getting Started, Opening Charts and Basic Trading: Open A Chart For continuous futures contract charts, refer to: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
