Date/Time: Mon, 17 Mar 2025 03:54:28 +0000
[User Discussion] - keyboard shortcuts and charts
View Count: 3638
[2020-05-06 14:49:59] |
a Gem Tree - Posts: 60 |
I've been looking through the hotkey options list - friggen HUGE!! Quite the effort to complete. But I cannot seem to find a shortcut option for charts (not chartbooks). Is there a hotkey option to select (say), chart #7 ? I have a few charts in my book, and I would like to not have to scroll all the way over to that chart and click it, in order to use buy sell hotkeys. Since I have 4 monitors - I am always clicking other charts. These charts are a different symbol than the vehicle I'm trading, so I cannot enable them for trading / hotkeys. Actually, my trade window is pretty small, and It's hard to get to. If this isn't an option for hotkeys, would you consider adding it? |
[2020-05-06 21:44:35] |
Ackin - Posts: 1865 |
Is there a hotkey option to select (say), chart #7 ? I use: CTRL+ALT+A... chart number+enter btw Hotkey list (very old but good... thanks User78286) Many commands in Trading Keyboard Shortcuts are not working | Post: 55915 Date Time Of Last Edit: 2020-05-06 21:58:48
[2020-05-06 23:45:50] |
I don't follow what you're saying. For me, control alt a is alert log. I still do not understand how to hotkey certain charts in a chartbook. Can anyone help? |
[2020-05-07 00:45:24] |
JohnR - User831573 - Posts: 320 |
For my setup, by default, it has CTRL-ALT-A as Alert. In the Windows menu, there are 3 possible choices, Previous Chart-> F4 Next Chart-> F9 and GoTo Chart Number, causes a popup window where you enter the chart # you want to go to. By default this does not have a keyboard shortcut, but you could assign one. Or you could use AutoHotKey, a keyboard macro program that support suggests and you could assign the entire thing to a key combo, including the chart # you wanted to jump to. JohnR |
[2020-05-07 07:01:04] |
I have default it what i wrote above. Maybe I've changed in the past. I don't know. I have been using sierrachart almost 10 years every day. try and set: Global settings >> Customize Chart Shortcut Menu .. ADD-> .. Goto Chart Number Global settings >> Customize Keyboard Shortcuts >> Window .. Goto Chart Number edit: I have SCH 2091 ver Date Time Of Last Edit: 2020-05-07 07:27:23
[2020-05-07 07:17:24] |
Attached pic
[2022-08-19 09:32:39] |
User907967 - Posts: 54 |
Hi, would it be possible to see a tabular version of all the keyboard shortcuts in their current settings? This could be a spreadsheet (or a read-only interface) with two simple columns: [keyboard combination] and the [Sierra predefined action]. This view may not be editable. This is just to show a complete perspective of all the keyboard shortcuts configured. Thank you. Bogdan |
