Date/Time: Thu, 06 Feb 2025 18:15:15 +0000
Resolution changed
View Count: 1012
[2020-05-06 13:50:44] |
User223281 - Posts: 58 |
Hello, For some reason, upon reconnecting the external monitor to my computer, the resolution has changed. All the lines are very thin, and drawing text is so small its nearly unreadable. I changed all the global font and text settings, as well as the chart font and text settings, but that hasn't changed the size of the resolution within the chart. |
[2020-05-06 14:06:28] |
Richard Chinn - Posts: 28 |
I Don't Know If This Helps Or Not But My Computer Resolution Was Changed This Morning As Well. I Also Use External Monitors. Sierra Chart Was NOT Running. My Computer Is Set To Do Windows Updates On Tuesday Nights. I Think Something In The Windows Update Caused The Resolution Change. A Windows Update Did Happen On My Computer Last Night! |
[2020-05-06 20:41:45] |
Refer to: Graphics Settings: Font Sizes Unexpectedly Changing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
