Date/Time: Thu, 06 Feb 2025 17:53:20 +0000
Control Bar - Icons were labeled with symbols now using text
View Count: 499
[2020-05-06 01:02:14] |
superdoug3 - Posts: 40 |
I updated from V2022 to current Version. In prior version the icons on my control Bar were identified with symbols but current version has Control Bar icons labeled with text. for example: V2922 had a picture of a line on the Icon for line drawing, Now current version for the same icon uses for a label "line". I prefer the symbols and I tried to find an option for this. I tried all of the customizing options for Control Bar and I tried search of support forum . |
[2020-05-06 08:47:12] |
Refer to the notes here about this: https://www.sierrachart.com/index.php?page=doc/Whats_New.php#SCVer2065 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
