Date/Time: Thu, 13 Mar 2025 16:35:16 +0000
Dorman TT CME data
View Count: 627
[2020-05-05 22:34:37] |
Robert Wojczak - Posts: 149 |
Can you please walk me through how to connect now that I am all set up with Dorman.. Thanks
[2020-05-06 01:20:12] |
Yes we will have someone call you about this.
[2020-05-06 01:30:40] |
can you have somebody call me between 6am-7pm tomorrow morning 5/6/2020 732-500-3701 thank you |
[2020-05-06 13:05:20] |
Can you have somebody call me please to set this up 732-500-3701
[2020-05-06 13:28:24] |
SC Support - Posts: 1941 |
Hi Robert, we can still call you if you need set-up help. Thank you
[2020-05-06 13:49:05] |
yes I need help please
[2020-05-06 14:14:14] |
Will you be calling soon. I want to get this working I switched from Rithmic to your system some help would be appreciated
[2020-05-06 14:35:09] |
Spoke to Robert, helped with his set-up.
[2020-05-06 15:24:55] |
Thank you Ray Very helpful
