Date/Time: Mon, 25 Nov 2024 06:32:46 +0000
High resolution (retina( display issues
View Count: 1386
[2014-01-19 14:53:13] |
1upTrader - Posts: 2 |
Hello, I am trying to get SC reconfigured on a new retina display MBP. I have managed to change most of the fonts to reasonable sizes, but am still have issues with the toolbar and chart tab sizing. Can you point me in the right direction? |
SC_Render1.png / V - Attached On 2014-01-19 14:51:20 UTC - Size: 34.39 KB - 481 views SC_Render2.png / V - Attached On 2014-01-19 14:51:33 UTC - Size: 33.13 KB - 473 views Attachment Deleted. |
[2014-01-20 17:59:39] |
We will add a task to be able to specify the specific font properties for the ToolBar text and Chartbook and MDI window tabs text.
[2014-01-22 06:53:15] |
Thank you!
