Date/Time: Thu, 06 Feb 2025 17:45:46 +0000
Data Package
View Count: 475
[2020-05-05 17:04:43] |
User559715 - Posts: 1 |
Are all the benefits of activating denali data feed through Sierra Charts available if I instead use AMP futures to activate Denali data with TT (FIX) routing? I'm actually concerned about server side OCO's and bracket order, low latency etc. Also, would I be able to access TT's online trading panel
[2020-05-06 08:22:34] |
Yes you can certainly access all of this through AMP. You have all of the same benefits. You can use TT's trading panel as well. We have one as well: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#WebBasedTradingPanel Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-06 08:23:07
