Date/Time: Thu, 24 Sep 2026 21:53:20 +0000
Data Feed
View Count: 1201
| [2020-05-05 16:54:27] |
| User298180 - Posts: 7 |
Hi my broker is AMP Futures and I am currently using CQG Qtrader to enter market orders, I would like to run an instance of Sierra chart at the same time for some additional charting but don't need to submit orders through it. What is the cheapest way to do this? Is it possible to use your data service and just log in once a month to get the live data and not incur having to pay a second set of exchange data fees? The exchanges that I am using are CME bundle non-pro & Eurex. Also does it make a difference if you are using two separate computers? If not, how much would it cost to do with an additional CQG data feed vs your own data feed and would I need to pay for a second set of exchange data feeds? Thanks |
| [2020-05-06 08:27:28] |
You definitely are going to have to pay for the exchange fees twice. If you are just needing data from the CME Group, then refer to the information here for the Denali Exchange Data Feed, including the costs: Denali Exchange Data Feed If you need data from other exchanges, then refer to the information here for the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed You would need to use both feeds for both CME Group and EUREX. We are going to be adding the EUREX feed to the Denali Exchange Data Feed as soon as possible. Right now it is available through the Sierra Chart Exchange Data Feed. To confirm the trading account we recommend this solution: Easy Solution to CME Funded Trading Account Requirement Or you could just have AMP set you up with another CQG account. You have to ask them about pricing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-06 08:32:44
