Date/Time: Thu, 06 Feb 2025 18:17:23 +0000
Trading one SC account with two brokers?
View Count: 496
[2020-05-05 16:24:49] |
YogiBear - Posts: 4 |
Dear Ladies and Gentlemen, I'm trading with OneUp Trader, Sierra Chart and Rithmic. Now, I'm looking forward to trade with AMP, Sierra Chart and Rithmic. Most likely Mini DAX (FDAX) on EUREX, which is not possible with OneUp. Here are my questions: 1. Is it OK to use the login credentials from AMP for trading on the current Sierra Chart account? 2. Do I need a seperate, second Sierra Chart account when trading with AMP? It is not my intention to trade parallel. SC with OneUp or AMP at a time. |
[2020-05-06 08:30:45] |
1.Yes this is fine. 2. No. Also refer to: Using Multiple Data and Trading Services at the Same Time Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
