Date/Time: Mon, 25 Nov 2024 05:43:31 +0000
Countinuous Futures Contract replay issue
View Count: 1141
[2014-01-19 08:50:31] |
User42282 - Posts: 41 |
Hi SC team, thank you so much for this great functionality! I test the functionality of the replay in pre-release 1078. I load maximum of tick data for continuous contract YMH4 and NQH4 (SC Historical intraday futures data). It loads fine from end of 2006. Replay dies for both contracts the 20.12.2007. It occured for different replays for 1M and 5M charts. SC instances are all connected to one common remote SC as a source of data. No error is in the log. Mirek Date Time Of Last Edit: 2014-01-19 21:17:36
[2014-01-19 12:02:37] |
Good news, it is a problem with data, not with replay itself. Data redownload didnt help though. Log says: Volume based rollover from NQZ7 to NQH8 occurs at 0 | 2014-01-19 02:53:59 So the rollover is not determined correctly, xxZ7/xxH8 is the point where replay stops. It works correctly when "Date rule rollover" is selected. Nice weekend to you all Mirek |
[2014-01-19 20:44:13] |
We have implemented some changes to prevent the replay from stopping in this kind of scenario.
