Date/Time: Wed, 27 Nov 2024 00:25:11 +0000
sc.AddLineUntilFutureIntersectionEx()
View Count: 773
[2020-05-04 22:47:58] |
cfuture - Posts: 67 |
the explanation of this function also refers to an example: "For an example to use the function, refer to the scsf_ExtendClosesUntilFutureIntersection function in the /ACS_Source/studies5.cpp in the Sierra Chart installation folder." This example fails to represent the above-mentioned function in regard to the numerous parameters. Is there a better example showing all the needed parameters to be considered?
[2020-05-05 11:08:34] |
The documentation for that function was not yet updated. It is now updated and makes reference to an actual example: sc.AddLineUntilFutureIntersectionEx() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-05 11:09:00
[2023-10-06 00:44:46] |
j4ytr4der_ - Posts: 938 |
What is the difference between sc.AddLineUntilFutureIntersection() and sc.AddLineUntilFutureIntersectionEx()? I've read them both and I see some minor items that are not the same but bigger picture, why use one over the other?
[2023-10-06 17:32:10] |
Sierra_Chart Engineering - Posts: 17187 |
There are a lot more variables in the related structure: sc.AddLineUntilFutureIntersectionEx() Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
