Date/Time: Thu, 06 Feb 2025 15:58:22 +0000
Download
View Count: 575
[2020-05-04 17:27:39] |
phil - Posts: 1 |
hallo liebes Sierra chart team, wenn ich sierra chart downloaden möchte, hängt sich der installer immer wieder auf und zeigt keine rückmeldung an, brauche hilfe ! lg philipp |
[2020-05-04 20:01:13] |
From Google Translate: if i want to download sierra chart, the installer keeps hanging and does not show any feedback, need help!
In this case we recommend using the zip files installer to update Sierra Chart: Software Download: Sierra Chart Zip Installer Be sure to extract the files into: C:\SierraChart\ Do this when Sierra Chart is not running. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-04 20:02:44
