Date/Time: Thu, 06 Feb 2025 15:52:00 +0000
Dorman
View Count: 1496
[2020-05-04 15:26:25] |
Robert Wojczak - Posts: 147 |
I just opened an account with Dorman. I want to use the Denali data feed and trade through Sierra Charts. Can you help me set this up
[2020-05-04 16:52:12] |
We assume you mean you want to use the Sierra Chart Order Routing Service. If we are understanding this correctly, then follow the setup instructions here: https://www.sierrachart.com/index.php?page=doc/SierraChartOrderRoutingServiceWithData.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-04 19:31:54] |
Are there any additional per (trade)transaction fees to trade through TT an Denali? Thank You
[2020-05-04 19:46:00] |
There is a $0.10 fee per order fill per side and you can have this billed to your Dorman account. This is less than Rithmic which is $0.25
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2020-05-04 19:46:15
