Date/Time: Thu, 06 Feb 2025 20:20:22 +0000
[User Discussion] - How to show OHLC of sub-graph (indicator) bars in Compact Values window?
View Count: 714
[2020-05-04 14:56:20] |
mittalpa - Posts: 28 |
Hi Sierrra Engg, I can see ohlc of main price bars in Compact Values window. Then, I added Volume ratio indicator in sub-graph but unable to see OHLC of Volume difference bars. How to show OHLC of sub-graph (indicators) bars in Compact Values window? Thanks Date Time Of Last Edit: 2020-05-05 12:34:38
[2020-05-08 13:18:13] |
Sierrra Engg, Is this feature not available? Thanks |
[2020-05-08 13:27:36] |
Ackin - Posts: 1865 |
just idea: when the subgraph is of the "candle" type: use 4 x simple moving averages study with settings period 1 based on subgraphs O,H,L,C when the subgraph is of the "bar" type: use max/min study based on your subgraph you will always have to point the cross at the desired region anyway The Compact Tool Values Window displays the value for each Subgraph for the first study or the main price graph in the Chart Region that you are currently pointing to when using one of the Drawing Tools. Additional data relating to the Drawing Tool you are using is also displayed in this window.
Date Time Of Last Edit: 2020-05-08 13:30:02
[2020-05-08 20:46:00] |
Thanks.. will try it.
