Date/Time: Thu, 06 Feb 2025 16:09:54 +0000
Spreadsheet study subgraph offset
View Count: 729
[2020-05-04 14:14:34]
Sam - Posts: 9
I would like to know if it is possible to offset spreadsheet study subgraph.
I created 3 different signals that come from the same spreadsheet.
These signals can trigger all at the same time if a condition is met so they tend to overlap on each other.
I know I can use displacement but this is not what I am looking for.
I am looking to offset their vertical position instead.
Is this possible?
Thank you!
Sam
[2020-05-04 19:17:37]
You just do that within the formulas themselves. The formulas need to return values at the value levels that you want them to be drawn at.
