Date/Time: Thu, 06 Feb 2025 14:57:49 +0000
No data on DOM Eurex
View Count: 668
[2020-05-04 05:42:38] |
User657945 - Posts: 226 |
I Team some week ago I discovered and you confirmed that there are issue on the delay of the Eurex flow due to barchart eurex flow, today I got a new bad surprise as you can see from the attached image the Bund and the dax too has no more the 10 levels up and down but only 2 levels on the book! Till friday it was ok please check and bring back the data please. thx Alberto |
Attachment Deleted. nodata on dom eurex.PNG / V - Attached On 2020-05-04 05:42:26 UTC - Size: 22.05 KB - 203 views |
[2020-05-04 06:05:54] |
We are not seeing any problems with the market depth data for the EUREX data feed from the Sierra Chart Exchange Data Feed. Make sure there are no settings restricting the number of levels on your side: File Menu: Not Receiving the Full Number of Market Depth Levels Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-04 07:28:13] |
OK but I did not change anything from friday so how is it possible?As you can see in my chart it's not working. Coould you please help me?
Date Time Of Last Edit: 2020-05-04 07:29:50
[2020-05-04 07:39:24] |
I did check all the settings described into your istruction and as exepceted are all set as reqeusted and how they were friday so please help i can't work this way.thx
[2020-05-04 07:45:21] |
OK guys not clear what it was I closed and then reopen Sierrachart and now it's working, something went wrong probably during the first loading. Discard the request.thx
Date Time Of Last Edit: 2020-05-04 07:45:38
