Date/Time: Thu, 06 Feb 2025 15:31:03 +0000
ECIVWAP Causing CPU Exception on SC version 2098 & 2099
View Count: 521
[2020-05-04 04:07:22]
BlakJak - Posts: 108
I get this error from a study I have been using for months without change. Only change was upgrading to the newer versions.
"Warning: The Custom DLL study "UserContributedStudies_64.scsf_ECIVwap" has just caused a CPU exception. | 2020-05-04 00:05:19.561"
Should I rollback to previous version?
[2020-05-04 04:35:19]
OK - rolling back to 2096 doesn't seem to fix it. I rebooted my computer and that also does not fix it.
This study is really important to me. Please help.
[2020-05-04 04:37:18]
User Contributed Studies just needs to be updated. Follow the instructions here to update Sierra Chart:
And then enable Install Optional Components on the installer window.
