Date/Time: Thu, 06 Feb 2025 16:04:04 +0000
Problem with Bid & Ask Depth Bar Study
View Count: 603
[2020-05-04 03:26:50] |
User29419 - Posts: 19 |
At about 20:33 Central Time it appears Bid side from the order book stopped registering for the first 5 bid prices in the Bid & Ask Depth Bar Studies. If I set the Chart "Maximum depth levels" to any value 1-5, nothing registers on the Bid side (Calculation Mode: Sum Bid Side). Any value greater than 6 appears to register the Bid depth. Everything seems to be fine for the Ask side in the study. I am using Sierra Data with the Denali exchange data feed.
[2020-05-04 10:16:43] |
This should now be resolved.
