Date/Time: Thu, 06 Feb 2025 14:47:11 +0000
If not IB what is best for ES trading only?
View Count: 508
[2020-05-03 22:12:11]
Ryan McDonald - Posts: 9
I have used you guys for charts now a few years and used IB over 15 years, you guys have been great on the chart side. I think I called IB 2-3 times for support :) If I am trading only the ES and no stocks or anything else and my only care is a solid broker what would be the best setup for data-feed / trade execution? The reason I still use IB is because even if I get stopped on 20 contracts I have had 0 issues with slippage but again I have not looked into anyone else because what I have works, I just keep seeing all the errors and your posts on it so wanted to revisit this topic.
Thanks again
Ryan
[2020-05-04 00:12:11]
If you are trading CME group futures through Interactive Brokers, we recommend using the Sierra Chart Order Routing Service instead of Interactive Brokers:
Sierra Chart / Trading Technologies Futures Order Routing Service
It is supported by many brokers/clearing firms.
You probably will find that you will save on commissions. And we are quite confident order routing is going to be even faster for you.
