Date/Time: Thu, 06 Feb 2025 17:03:14 +0000
[User Discussion] - i need to create bid & ask indicator
View Count: 671
[2020-05-03 21:37:44] |
Zeroone - Posts: 11 |
i need create to indicator with bid/ask for the tick on bar, do you say me wath is the variable for the bid/aks in the tick/price on the bar?
[2020-05-04 20:11:29] |
Have a look at the Numbers Bars study: Numbers Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2020-05-05 08:55:04] |
This study show the value, but i need the ascii variable for ticks (ask/bid) for a new indicator
