Date/Time: Thu, 06 Feb 2025 15:51:15 +0000
chart values window for Bar crosshairs are on
View Count: 1422
[2020-05-03 19:28:36]
JohnR - User831573 - Posts: 309
I have read the docs as well as searched and read support board. I would like to have a popup window that looks like the current "Chart Values" window, but will show the values for the bar the cursor/crosshair is on as I scroll across a chart. I do this during my research / planning phases. The only thing I can get the Chart Values Window to show is the Last displayed bar. so it kinda does what I want but then I have to scroll the chart, and some times III want to see the chart values with the desired bar being in the middle of a window. I have looked at Compact Chart Window, but that only shows values for the region the cursor is in. If this is not currently possible, Is there sample code for the Chart Window available I could use and I would program mine to be tied to a button to turn it off and on.
Thanks in advance for your time to reply
JohnR
imageChart Values Window.jpg / V - Attached On 2020-05-03 19:28:20 UTC - Size: 82.78 KB - 282 views
[2020-05-04 00:33:38]
This is explained here:
Chart Drawing Tools: Viewing Tool and Chart Data When Using Tools (Viewing Tool and Chart Data When Using Tools)
[2020-05-04 12:47:28]
First, Support Folks --> Thank you for the time to reply.
For other newbies, I would also like to add, for me to see this window, I needed to also reset windows from within SierraChart. Not sure what I messed up in trying different things as I was / am getting used to more and more features of SierraChart.
From any chart window or the main control window -->>> click on the menu -> Window -> Window Reset ( top of 2nd column for me).
JohnR
