Date/Time: Thu, 24 Sep 2026 05:55:58 +0000
Linux
View Count: 2063
[2020-05-03 14:44:13]
LucentTrader - Posts: 41
Does Sierra have plans for running on Linux?
[2020-05-03 16:06:38]
T44 - Posts: 363
Documented: Run Sierra Chart on GNU/Linux, BSD, and Mac OS X using Wine
SC Engineering no longer recommend Linux.
Perhaps try xfreerdp or remmina on Linux connecting to a Windows Server cloud instance?
[2020-05-03 20:29:26]
ticinotrader - Posts: 429
LucentTrader - everything you need to run SC on Linux is described here:
Linux
T44 - Re SC Engineers do not recommend Linux: it is a quite steep statement. Using the exact same hardware configuration, SC runs more smoothly on Linux/Wine than on any Win OS.
It is like cabriolet cars - they run better without windows...
[2020-05-04 02:27:18]
ganz - Posts: 1048
ticinotrader
https://itvision.altervista.org/why.linux.is.not.ready.for.the.desktop.current.html
and wheels
[2020-05-04 03:02:42]
ertrader - Posts: 698
as ticinotrader mentioned...linux/wine is working really well. Frankly much better than on windows 10 for me. My production trading platform is Mint Linux/wine. I always identify issues on Wine first and then duplicate on Windows 10 every time so support has actionable examples.
Hopefully, someday, SC will have a native Linux version but until then Wine is working better than Windows 10!
[2020-05-04 03:14:01]
In regards to post #5, that is good to know.
[2020-05-04 12:48:02]
ganz - Posts: 1048
LucentTrader
be careful and ignore that geeks, bro
dmesg | grep -ie error
dmesg | grep -ie fail
there are extremely limited lists of fully supported hw by vendors
http://h20195.www2.hp.com/v2/GetDocument.aspx?docname=4AA7-6280ENW
https://dlcdnimgs.asus.com/websites/global/aboutASUS/OS/Linux-Status-report-201810.pdf
https://fedoramagazine.org/coming-soon-fedora-on-lenovo-laptops/
and so on
also don't lay on Canonical's info it's just crap
lol
https://bugs.winehq.org/buglist.cgi?bug_status=UNCONFIRMED&bug_status=NEW&bug_status=REOPENED&limit=0&order=bug_id&query_format=advanced
Date Time Of Last Edit: 2020-05-04 13:09:57
[2020-05-04 14:25:34]
AlexPereira - Posts: 197
I think it was planned years ago, but it never delivered, I don't think you should make plans counting on it. Especially now since SC seems focused on other areas.
But before you discard it, you should try it through wine and make up your own mind. Although remember, SC does not support it, so any problem you are on your own ( although here the linux community will help ).
In my experience, I can backup etrader and ticinotrader claims.
[2020-05-05 08:36:54]
It is interesting the perspective that users have and how it is incorrect. In response to post #8, refer to:
Native Support for Linux. Will This Ever Come?
Date Time Of Last Edit: 2020-05-05 08:36:59
[2020-05-05 10:49:17]
I was aware that you were refactoring code...for some years now, but I got the idea that you were focusing on other areas, especially the feeds and routing.
Glad that I was wrong and Linux client is still planned.
